Pump And Motor Assy. Replace Item #7 Filter This Is What I Have Tried. 1. I Removed The 6 Screws Item #6. It Then Appears That Item #32 Along With Items #1 To #6 Should Lift Off, It Doesn't. I Do Not Want To Put Excessive Force On Item #32 Because Many Of These Parts (#1-#6) Are Plastic And "out Of Stock," Forever. Once I Get Item #32 Off Item #7 Should Be "a Piece Of Cake" To Replace. Question,how Do I Get Item #32 Along With Items #1 To #5 To Lift Off Of Item #31?? I Have Replaced The Door Gasket. All The Parts Were Purchased Through You Company.:)
Originally Posted by: jerry bahnsen  Pump And Motor Assy. Replace Item #7 Filter This Is What I Have Tried. 1. I Removed The 6 Screws Item #6. It Then Appears That Item #32 Along With Items #1 To #6 Should Lift Off, It Doesn't. I Do Not Want To Put Excessive Force On Item #32 Because Many Of These Parts (#1-#6) Are Plastic And "out Of Stock," Forever. Once I Get Item #32 Off Item #7 Should Be "a Piece Of Cake" To Replace. Question,how Do I Get Item #32 Along With Items #1 To #5 To Lift Off Of Item #31?? I Have Replaced The Door Gasket. All The Parts Were Purchased Through You Company.:) JERRY BAHNSEN jmbahnsen@q.com
