panman
#1 Posted : Sunday, January 4, 2009 4:56:22 PM(UTC)
panman
Dryer runs for awhile then shuts down before clothes are dry. The digital readout will then show an HP(heat problem)fault code. I have to restart the dryer a couple times before the clothes are completely dry.
#2 Posted : Sunday, January 4, 2009 7:25:03 PM(UTC)
Pretty hard to diagnose without a Model Number
First thing I would do is clean and check the vent system (make sure the outside vent louvers open fully).
panman
#3 Posted : Thursday, January 8, 2009 8:37:48 AM(UTC)
panman
Maytag model MCG8000AWW.
#4 Posted : Thursday, January 8, 2009 11:16:28 AM(UTC)
Here is your parts breakdown
Model MCG8000AWW
Here is the tech sheet and service manual
http://www.servicematters.com/m...ibrary/docs/16022785.pdf
http://www.servicematters.com/m...ibrary/docs/16023137.pdf
Seems like venting/lint is the most common cause
