Just trying to figure out part to replace next. Refrigerator damper control or frzr temp control. Maybe other? Unit started clicking cycle and would never cycle off. I immediately thought the worst, compressor, but didn’t want to overreact. I replaced the overload and relay, but no change. It seemed to run cold so long until something overheated and emergency shut off, then compressor would not blow cold again until I powered down for at least an hour sometimes longer. I noticed the temperature control in freezer would not cycle off the unit as I turned warmer until I got all the way to OFF. Once the unit cooled down I could plug in and it would cool all the way down to -15 in freezer, so I started pulling plug to manually cycle off and on. This has worked for maybe 10 days now. Plug in to -10, pull plug, let freezer creep to 25 then plug in and down to -10, unplug, no problem if you have no life. I’m thinking it is the temp control in freezer that needs replacement. I'm happy to oder from your site, but which part? THANKS!
I think your correct in thinking the thermostat.
Nat
Seems the (1) freezer temperature control has thermostat as well as the (2) damper control in fridge. ALso there is a thermostat on (3) defrost timer, right, then there is a (4) thermostat kit THAT I HAVE NO IDEA WHERE IT GOES?
The temp control for the freezer should be the correct one. The one that you can turn to off and the unit will go off. That's the one that you need.
Nat
