linuxaz
#1 Posted : Sunday, January 4, 2009 8:43:05 AM(UTC)
linuxaz
Hello,
My Bosch has low pressure when running, and makes a slight clicking sound that appears to come from the motor / pump area. It has plenty of water in the basin. I have removed the machine, and inspected the impeller and think I need to replace it with the kit linked here I say this because the blue part of the impeller was loose from the clearish part. The motor tests good and spins freely. Let me know if I'm on the right track here. I'd gamble the 75.00 on the part, vs. call a tech and spend a couple of hundred. Thanks. linuxaz.
RedVonBaron2000
#2 Posted : Saturday, January 10, 2009 8:43:11 PM(UTC)
RedVonBaron2000
Linuxaz,
I do think you are on the right track having read through many other posts related to yours and what is similar to my problem (albeit no clicking). I have a Kenmore Elite (#630.16302400) which is made by Bosch and the part diagram @Sears matches exactly the one you link to making me think they are the same. If someone on the forum can comment on or confirm this that would be most helpful.
You say you already have the impeller off(?)/inspected -how long did this take you and how did you get the impeller off? One post mentions using an impact wrench which I don't have... ugh.
Red
btw - the part is only $67.99@Sears. - Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com
Lmsewell
#3 Posted : Tuesday, August 30, 2011 11:49:50 AM(UTC)
Lmsewell
I'm having the same problem ...how did you get access to the motor and impeller? And how did you test the motor?
