When dryer is on it squeaks...any suggestions how to check or oil or change belt....? Any suggestions are greatly appreciated :) :)
Pull front panel and check for worn glides. If bad replace with Pn AP2042543 If ok check the drum rear bearing, might be worn out.Replace with Pn AP2042531
