The gemini oven clock or any functions of the oven doesn't work. I try a new gemini clock but still nothing. The range eyes do work but nothing else. Need help with what to check next, like voltages. The black wire at terminal doesn't read 115 voltage when connected but only when took off the terminal? 240 voltages from black to red or red to white and 115 volts from red to white and no voltages from black to white only when connected to the range's pig tail terminals?
:confused: Originally Posted by: batman721  The gemini oven clock or any functions of the oven doesn't work. I try a new gemini clock but still nothing. The range eyes do work but nothing else. Need help with what to check next, like voltages. The black wire at terminal doesn't read 115 voltage when connected but only when took off the terminal? 240 voltages from black to red or red to white and 115 volts from red to white and no voltages from black to white only when connected to the range's pig tail terminals?
