bchapin
#1 Posted : Thursday, March 24, 2011 12:42:55 PM(UTC)
bchapin
I have a 90 series Kenmore heavy duty model top load washer. It stopped spinning and now it don't even want to pump water in. All it does when you turn the switch is make a buzzing noise like its trying to turn on but nothing happens? Any ideas???
sidfink43
#2 Posted : Friday, March 25, 2011 5:26:04 PM(UTC)
sidfink43
Well lets deal with the water problem first. Check to make sure your inlet valves are not clogged. Then use a meter to see if they are getting 110v when they are supposed to turn on. If not, I suspect the timer is the problem. If so, try replacing them and see if it will at least fill.
