my dish washer would not start the only thing it will do is when i push cancel it will drain the air dry light will light come on when i press the button then when it got dark out i notice all of the cycle lights are on very dim but none of the option lights are when each button is pressed the light goes out i just bought my home and dont have much of a history on it
Most likely the problem is a bad control panel. In order to provide the right part number I need the color of the control panel.
the control panel is white and some gray
The part number for the white control panel is AP3176986. Here are the break down diagrams for the Whirlpool dishwasher Model GU1500XTLQ2Gene.
