Hi I have a frigidaire 9 cycle washer model FWS 445rbs2. The only cycle I can get it to agitate on is Knits and Delicates. It will fill and go thru timer and then empty tub but not agitate or spin on any other cycle. What part would I order?
If it goes completely through the cycle on knits without any problem than it does not appear to have a mechanical issue. This suggests a new timer will solve your problem, but first take off the connections to the timer and clean them with a good contact cleaner and reseat them. Probably will not fix it, but hey, you never knowl.
