hi i have a Frigidaire, Washer/Dryer, (Stacked, Unit) it was working fine i wasked a load and put them in the dryer when i came home they where done so i tryed to start it back up to dry them to get the wrinkles out and the dryer wont start it dosnt even make no sound but when i push the start button and hold it you can hear the timer workin....any ideals...thank:confused: oh the washer works fine and i dont know how old the unit is
It is the thermal fuse. The part # is 134120900. If you stand on a chair, and take all the screws off the top cover on the dryer, and remove the top cover, you will see the thermal fuse on the top left hand corner. It is the size of a dime, and has 2 wires going to it. This is a easy one. Tom
thanks i will try that and let you know if it works
