The CLEAN lamp blinks 7 times and repeats this continuosly. I can not do any function except pressing STOP causes a 2 minute drain. Pressing any of the wash cycle buttons or any option button causes the correct lamps to light. Pressing START has no effect. The console assembly and the control, electronic have both been replaced. What else can I check or replace?
It is finally fixed. The first control panel was defective. The second one works fine.
