I have replaced this part twice and none of them is working. When I replaced it, it says on the dispenser front panel PE0-000. Please I need to know if I have to replace something else or this part need a special configuration. With the old part doesn't work the Freezer Fan but the compressor is working without a problem. When I replace with your Part # AP4568436(W10310240) works the freezer fan but doesn't work the compressor. Do I need to replace something else? please let me know. Attached is the picture of the old part from this Maytag Refrigerator[FONT='Calibri','sans-serif'] MFI2568AES12 Black with Stainless Steel doors.[/FONT] Thanks Tommy Velasco tvelasco attached the following image(s):
What is the complete model number of the refrigerator?
Hi Gene, the Model # is MFI2568AES12 Black cabinet with stainless steel doors. Thanks Tommy
Hi Gene, I already got the replacement and I'm still having the same problem. Originally Posted by: Gene
In such situation I"m afraid it is beyond remote diagnosis. Probably you have to call a pro.
no problem, thank you much anyway Thanks Originally Posted by: Gene  In such situation I"m afraid it is beyond remote diagnosis. Probably you have to call a pro.
:mad: :confused: 09-30-2013
I purchased the same HV board and my fridge no longer keeps anything cold. The old board kept things cold, but the ice maker nor the water dispenser worked. I was better off with the old HV board now I am loosing food. I am looking at a 4 year old blog hasn't someone come up with an answer yet.:(
PE00000 coding problem Originally Posted by: Deborah Simpson  :mad: :confused: 09-30-2013
