RyanLeah
#1 Posted : Friday, January 2, 2009 6:39:17 AM(UTC)
RyanLeah
When I select a wash cycle the detergent cup switch instantly opens and remains jammed open buzzing. It seems like it is getting constant power.
What do I need to replace?
Thanks!
#2 Posted : Friday, January 2, 2009 5:23:06 PM(UTC)
Remove the inner door panel and check all wires. If there is nothing wrong then, most likely, the problem is a bad control board.
- The part number for the control board is AP3775964
Here are the break down diagrams for the Whirlpool dishwasher Model GU1500XTLS0
