I have checked power to outlet and have my 220. I have checked power to teminal block and have it there. The dryer will not turn on and when the door is open, ther is no light. Could this be the thermal fuse or another fuse?
First check for disconnected or bad door switch.
Door switch was ok, the fuse at the element was bad, I am in the process of chainging it now.Thanks.
Originally Posted by: Gabesrepair Door switch was ok, the fuse at the element was bad, I am in the process of chainging it now.Thanks. I changed the fuse at the element. Everything is working, thanks for all your help. If I need assistance in the future I will be sure to get online and talk to you guys.
