PhotoBiker
#1 Posted : Saturday, March 19, 2011 6:35:54 AM(UTC)
PhotoBiker
Had some kitchen repairs (not related to the dishwasher) on Thursday. Workers had to disconnect the dishwasher and move it into another room while our kitchen was dismantled (long story, good thing for insurance).
Anyway, I went to reconnect it last night and found that there is a leak coming from the Air Intake on the left hand side. I can't see if the plastic housing itself is cracked (which would make sense if it got whacked in all the commotion) or if the gasket is bad.
I did find this parts break out online:
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDC25CHBL1/0593/0130000/W0207075/00006?blt=06&prst=&shdMod=
Item #3 (#9744519 or substitute #675828).
My question is relatively simple [stupid], how do you remove the air inlet? I tried twisting it around and spinning the Inlet Bezel from the inside, but no luck. I'd like to take the thing apart to get a better look at it.
Thanks,
#2 Posted : Saturday, March 19, 2011 7:42:49 AM(UTC)
See the attachment, it shows how to remove the vent. I think the water inlet is the same or very close
Replacement parts for WHIRLPOOL KUDC25CHBL1 | AppliancePartsPros.com
They do say "Water inlet assembly - Corrected to stop moisture from escaping." (Item 3 in Section 6 so I assume they have had problems in this area and this is an update.
File Attachment(s):
KUDC25.pdf (484kb) downloaded 93 time(s).
PhotoBiker
#3 Posted : Saturday, March 19, 2011 11:21:37 AM(UTC)
PhotoBiker
Thanks.
I tried that earlier, I have the English and French Service sheets that this PDF came from still attached to the back of the kick plate. I will try it again though as it really does make sense.
It looks like there are instructions included with the part, but I don't know if I need the part yet.
#4 Posted : Saturday, March 19, 2011 2:08:37 PM(UTC)
I will take a look to see if I can find that instruction sheet for you.
#5 Posted : Saturday, March 19, 2011 2:37:17 PM(UTC)
Found it, I think, I hope!!
See attachment
File Attachment(s):
Air Inlet.pdf (390kb) downloaded 108 time(s).
PhotoBiker
#6 Posted : Saturday, March 19, 2011 6:22:03 PM(UTC)
PhotoBiker
Awesome. Thanks.
And it appears as if you were correct with your first assumption. I will get a bigger screwdriver and try a little harder now ;-)
hpoche
#7 Posted : Saturday, November 3, 2012 2:42:48 PM(UTC)
hpoche
See attachment
this really saved us alot of money. thanks so much for posting this.
