joebe
#1 Posted : Thursday, January 1, 2009 6:29:11 AM(UTC)
joebe
Rear roller does not look like it is made to be replaced, but mine is cracked and needs to be replaced. What is the procedure for replacing this wheel. Thanks. joe:confused:
TechnicianBrian
#2 Posted : Thursday, January 1, 2009 7:08:52 AM(UTC)
TechnicianBrian
The bottom system pan is held in place with a bolt on each corner, bottom rear of the unit. Remove the bolt and with some assistance, the pan can be pushed down enough to remove the roller shaft out the side dropping the roller. Put in a new roller (Part# AP3108943), put the shaft back in and then reinstall the bolt.
