heather608
#1 Posted : Friday, March 18, 2011 5:01:11 PM(UTC)
heather608
3 nights ago it stopped heating up and runs non stop. I cleaned out the vent duct going outside and and the vent duct where the lint trap goes. I have also changed the thermal fuse. Still no heat. Momm with 4 kids and need fixed laundry piling up FAST!
#2 Posted : Saturday, March 19, 2011 4:10:14 AM(UTC)
Could not find any info on the given model number. Closest I could get is RED4440SQ0.
Replacement parts for WHIRLPOOL RED4440SQ0 29``ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
If the fuse you replaced was Item 7 in Section 3 then that would not have solved your problem as this is the fuse in the motor circuit and the motor would have been dead.
First you have to check the power. The motor and interior light run off of 120 volts but the heater requires the full 240 volts. On most units this is a bit dangerous but this unit lets you check it easily. Put the unit into timed dry and let it run. If the timer advances then you have the 240 volts as the timer also runs directly off of the 240 volts in timed dry mode.
If it does not have 240 volts try flipping the breaker off/on a couple times. Sometimes you can loose half the line without actually tripping the breaker.
If you have 240 volts then unplug the unit and check the heating coil, usually around 10 ohms.
If OK
Check the thermal cut-off, hi-limit thermostat and the operating thermostat, all should be 0 ohms.
Note: Your operating thermostat has 4 connectors.
2 of them are the contacts, they should be 0 ohms.
The other 2 are an internal heater they are usually up around 30,000 ohms.
If the thermal cut-off is blown get back to the forum as there are other things you should check before replacing it.
File Attachment(s):
RED4440.pdf (190kb) downloaded 7 time(s).
