rsigala
#1 Posted : Friday, March 18, 2011 2:28:56 PM(UTC)
rsigala
The model above is overflowing intermittently. Sometimes it overflows and sometimes it doesn't. If I turn the dial it will drain correctly and the water turns off if I push the button in to stop the washer. Why is it doing
it sometimes and not all the time? If it doesn't overflow it works just fine.
I just have to watch that it doesn't overflow.
sidfink43
#2 Posted : Sunday, March 20, 2011 6:04:45 AM(UTC)
sidfink43
Take off the front cover by inserting a screwdriver in the gap between the top and front near the edges to release clips that hold the front on.
You should see a plastic tube that runs from the left side of the tub to the console. This is an air tube that activates a pressure switch to stop and start the fill process. Clean out the tube and where it goes into the tub and that may fix your problem.
tlookin4one
#3 Posted : Tuesday, April 12, 2011 1:06:25 PM(UTC)
tlookin4one
My washer overflows on the wash cycle primarily. How do I check to see if its the water level switch or the intake valve that is causing the problem?
#4 Posted : Tuesday, April 12, 2011 4:11:22 PM(UTC)
In order to provide most accurate advice we need the complete model number of the washer.
GE Washer overflowing (Washer Repair)
by DanMnz 8/22/2012 5:28:56 AM(UTC)
