john brown
#1 Posted : 17 years ago
john brown
When Replacing The Inside Door Panel I Can Not Get The Dispenser Assemily To Connect To The Part Coming Down From The Timer. Is There A Trick To Getting The Teeth Lined Up.
#2 Posted : 17 years ago
Hi John
The first thing I would check is the locking tab on the right side of the console. If it's broken off then the follower cam will never engage with the soap cup actuator and the console has to be replaced.
If this is not the issue then make sure the timer is in off position and the follower cam is vertical.
Follower cam
UserPostedImage
Also make sure the drip cover is in the right position.
Drip cover
UserPostedImage
- The part number for the console AP3044513
- Here are the break down diagrams for the Whirlpool dishwasher Model DU900PCDB3
Good luck.
