widget925
#1 Posted : Wednesday, March 16, 2011 10:13:26 AM(UTC)
widget925
My dryer will not stay on. I set the tmer dial and press the on button. As soon as I let go of the on button it turns off. It will only run with pressure on the on button.
#2 Posted : Wednesday, March 16, 2011 6:28:28 PM(UTC)
Most likely the problem is a bad even heat control board (inside the control panel).
- The even heat control board Part number: AP4319168
Kenmore Elite Dryer will not stay on after pressing start switch (Dryer Repair)
by Flea 5/15/2011 7:21:26 PM(UTC)
