nolesman98
#1 Posted : Tuesday, March 15, 2011 8:45:49 AM(UTC)
nolesman98
Nothng is hot. It just stays on all the time. What do I do to fix this? Is it the switch?
#2 Posted : Wednesday, March 16, 2011 4:20:02 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for MAYTAG MER4320AAW RANGE- F/S STD ELE | AppliancePartsPros.com
It does sound like one of the switches is at fault.
Finding which one may be a pain.
Safesst way is to use a meter.
You could also do live testing but be very very careful as you are dealing with 240 volts which is lethal. Yo may want to get a pro in if you are not experienced working with electricity.
Unplug the unit whenever working in it.
Looks like you have 2 wires switching the indicator on (the blacks).
LF and LR also RF and RR.
If you have a meter, unplug the unit.
Remove the wire from the P connector of the control and then measure from L1 to P. With the control set to off it should be infinite ohms (open).
I am not 100% sure of this so if the first control you check shows 0 ohms check another one just to be sure it is infinite ohms (open).
You can also do a live testing but this is dangerous.
Unplug the unit
(A) Remove the wire at the control LR (P) going to the light.
Tape it up if you have to, to ensure it cannot short to anything.
Plug the unit in if the light is now off you know it is either the LF or LR control.
Unplug the unit, reattach the wire and remove the wire from the LF control.
Again tape it if you have to.
Plug the unit in.
If the light is on then the LR control is the culprit.
If the light is off Then the LF control is the probable culprit.
If in step (A), the light was on then the problem is on the Right side controls.
So just do the same testing to figure out which one is shot.
nolesman98
#3 Posted : Thursday, March 17, 2011 5:26:04 AM(UTC)
nolesman98
Thanks for your help.
KHIB
#4 Posted : Monday, February 20, 2012 3:58:56 PM(UTC)
KHIB
I have a similar problem with a different electric Maytag Oven Range Model #MER5530AAW. One of my burners short circuited and tripped the circuit breaker. I've replaced the burner and wiring and the burner now works fine. However, one of the surface indicator lights remains on all the time even though there is nothing cooking. Is this dangerous and could it cause I fire? How do I fix this light so it operates properly. Thank you for your help.
#5 Posted : Wednesday, February 22, 2012 4:47:27 AM(UTC)
KHIB
Here are your parts, includes a wiring diagram.
Replacement parts for Maytag MER5530AAW RANGE- S/C F/S ELE | AppliancePartsPros.com
One of the infinite control switches is holding the light on.
KHIB
#6 Posted : Thursday, February 23, 2012 4:33:59 AM(UTC)
KHIB
How do I open the control panel of my Maytag Range Model #MER5530AAW to get at this switch ? Can I reset this switch to fix it and if yes how would I do this or do I have to replace it with a new part/switch? Thank you.
