kevbraun
#1 Posted : Tuesday, December 30, 2008 4:25:10 AM(UTC)
kevbraun
I had an icemaker that wasn't working, the green light was blinking. I took the icemaker out and let it thaw out and put the icemaker back in and it worked. Problem is when reinstalling it I chewed up the side of the interior of the freezer which is no dented in a couple places by a sharp corner of the icemaker part. It does not appear to be punctured, but I would like to be able to fill those dents with something to make those spots a little sturdier. Is there anything recommended to patch the white shell of the interior of the freezer?
magician59
#2 Posted : Tuesday, December 30, 2008 5:33:55 AM(UTC)
magician59
You might try a can of expanding foam. Don't overdo it.
