tjnoel2
#1 Posted : Monday, March 14, 2011 7:22:51 PM(UTC)
tjnoel2
I replace the heating element, no problem. Before I knew which wires need to be removed I removed all the wires on the side of the housing. I think that I got them put back where they belong but I am not sure. Can someone please tell me which wire goes where so that I can know if I did get them put back in the correct place. The dryer does run but there is still no heat.
sidfink43
#2 Posted : Wednesday, March 16, 2011 6:34:13 AM(UTC)
sidfink43
If there is not a wiring diagram on the back of the dryer there should be one inside the console that will show you how to connect everything back up.
Before doing that, with the dryer unplugged, test the heating element and the thermal fuses/thermostats for continuity. Also check to make sure you are getting 120v to each side of the connection block.
That should do it.
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
