I have a Maytag dryer model MDE3000AYW. The drum won't turn.
I've taken the drum belt off and tried to run the motor. The motor shaft turns about 1/8 of a revolution, clicks and then repeats the cycle.
Is the motor bad? Are the bearings bad? Can the bearings be replaced without replacing the motor?
Thanks!
Here are your parts Replacement parts for MAYTAG MDE3000AYW DRYER- ELE | AppliancePartsPros.com[COLOR="DarkRed"]Is the motor bad? Are the bearings bad? [/COLOR] Yes, it does sound like a bad motor. I do not think that it is bad bearings. Sounds like the main winding may be burned out (open). [COLOR="DarkRed"]Can the bearings be replaced without replacing the motor?[/COLOR] No, you have to replace the motor. |
THIS FORUM IS DEAD!!!!!!! |
