Jake Magish
#1 Posted : Monday, December 29, 2008 2:58:16 PM(UTC)
Jake Magish
Not wanting to damage the finish how does one access the door latch mechinism inside the front cover. The hook assembly in the door is fine but the female receptical doesn't latch the hook from the door when pushed to close. That make anysense?:confused:
#2 Posted : Tuesday, December 30, 2008 1:21:24 PM(UTC)
Hi Jake,
You can find the complete instructions in the Service manual.
- The part number for the door latch assembly is AP252166
Here are the break down diagrams for the Maytag Neptune washer Model MAH6500AWW
