freezer on bottom freezes but refrigerator won't drop below 60
Hi, You can start checking the evaporator coil is not ice up
and to make sure your evaporator fan is running.
If it is ice up you have a defrost problem, you will need to check
your heater and your defrost t-stat located on evaporator coil
if heater is good replace Defrost t-stat and clean all the ice in the coil.
cleaned condenser set t-stat @ 5 checked this morning temp at 38-40 degrees don't know what was wrong but working now
condensor really dirty? that could be it.
