I have to go 24 ft and had the old plastic/rubber one piece vent pipe. Need to run a new length and wondering if it's OK to use the 8 ft. sections of the High Temperature "Transition" foil and join them together. I can't find anything that is one piece anywhere. This is an electric dryer NOT gas. Thanks.
Originally Posted by: linesider I have to go 24 ft and had the old plastic/rubber one piece vent pipe. Need to run a new length and wondering if it's OK to use the 8 ft. sections of the High Temperature "Transition" foil and join them together. I can't find anything that is one piece anywhere. This is an electric dryer NOT gas. Thanks. it is too long
