amandaok
#1 Posted : Monday, December 29, 2008 6:50:50 AM(UTC)
amandaok
my fridgidaire dryer is about 18 months old, and has stopped functioning. i was drying a load of clothes, a very small load, and it was working fine, opened the door to check the clothes, they were not dry so i closed the door, pressed the start button...nothing happened. this was maybe 20 minutes into a regular cycle, so i hadn't changed the time settings. we let it cool off, a few days later tried again, nothing. the lint trap was clean (in fact a couple of weeks before i had vacuumed it out) and i checked the hoses and they are fine.
this happened a coupel of months ago, and finally i threw a fit and told my husband i wanted the dryer fixed NOW and would not wait until we got out tax returns and simply buy a new one. i called around, and in my area reapirman charge $75+ just to come look at it. looking around online here today and when it first happened, i think it may be the thermo fuse or the sensor switch(?)...but is that something i can or should replace on my own, and where would i find the part? how expensive is it? it it's goingt o cost me more that say 75, 100 bucks to fix it, it woudl almost be cheaper to buy one on craigslist (or just wait until we get our tax returns, and buy a new set...but it seems so wasteful to buy a new one, since this one is only 18 months old! and there is nothing wrong with the washer...)
libertyappl
#2 Posted : Monday, December 29, 2008 8:22:51 AM(UTC)
libertyappl
For starters check the breaker box, turn the dryer breaker off then back on. If that doesn't help then proceed checking the plug to make sure you have 220 Volts at the plug, if that's ok continue checking.
Here's a parts breakdown Model FER311FS0.
With an Ohm meter you need to check #36 on page one for continuity. If it doesn't have continuity then replace that part (Thermal limiter <click here)
Let us know what you find.
Nat
amandaok
#3 Posted : Monday, December 29, 2008 8:35:23 AM(UTC)
amandaok
would that be page 36 in the user manual? i think that got thrown out, will look for one online.
libertyappl
#4 Posted : Monday, December 29, 2008 8:58:19 AM(UTC)
libertyappl
No, click on the model number link I posted above. It's item #36 on the drum page.
Nat
amandaok
#5 Posted : Monday, December 29, 2008 10:37:13 AM(UTC)
amandaok
that makes much more sense...
my husband is not the most handy guy, so my dad is coming to help us with it tonight.
