The burners will not light at all. There isnt a clicking sound like there is no ignition. Just wondering if anyone might have some ideas on what I should look at first. Where is the ingnitor located?
Originally Posted by: camaross23 The burners will not light at all. There isnt a clicking sound like there is no ignition. Just wondering if anyone might have some ideas on what I should look at first. Where is the ingnitor located? Camaross, Your top burner igniters are located on each burner base itself( the little white porcelain coverred wire, they do need to be kept clean, But you most likely have a damaged igniter switch, wire, or bad spark module. We can assist you better, with a proper model number off the range. :) :) :)
