volodia62
#1 Posted : Thursday, March 10, 2011 12:46:51 PM(UTC)
volodia62
How do I remove the Front Plate so I can install the Actuator-water part (AP3963432(241685703)). I took the 3 screws out as shown in Diagram, (#82 on the diagram N58XEAAAA1). The bottom is lose but the Top of the Plastic insert is tight and I don't want to brake the faceplate trying to take it off. What do I do????? Appreciate any help you can give. Thanks.....Volodia62.
Joe / APP Team
#2 Posted : Friday, March 11, 2011 10:36:16 AM(UTC)
Joe / APP Team
Volodia,
Here's a general dispenser assembly technical notes,
It pertains to all the dispenser models made by the manufacturer, there may or may not be some components on your unit as outlined in the note.
But this information will get you where you need to be.
GAINING ACCESS
Two gain access to the control area you will need to pull
the drip tray out first.
With the drip tray removed, remove the 3 screws at the
bottom of the front panel.
Lift/slide up on the front panel, there are tabs on the top of
the panel that slide into holes in the door panel.
Swing panel out to side, being careful not to pull the
wires out of the disconnect plug or the board itself.
Carefully unplug the wiring harness from the touch panel
on the front cover This will give you access to the control board.
On models with no selector on the front panel, when
you remove the front you can gain access directly to
dispenser because you do not have a touch pad or board on dispenser.
On models with electronic control to gain access to the
control, snap the light socket loose and remove the 6
small screws from the board.
Pull board straight out of housing. Disconnect plug on
left side of board. Disconnect 4 wires to dispenser
actuator switches.
With the board removed, remove the 3 screws from the
dispenser housing and pull the dispenser forward.
Remove water line from dispenser housing by pulling
straight out.
With the water line removed, the upper part of the
dispenser is free of the freezer door panel. The main
housing is part of the door panel, and is not removable.
The ice door and actuator switches, as well as the return
springs, can be serviced with the control module
removed.
Tension is held against both the water and ice actuator
by a stainless steel, two bladed spring mounted behind
the actuator switches. The spring is held in place with 2
screws.
The Actuators are held in place by stainless clamps at
each end of the actuator and the two bladed spring in
the middle. The actuators can be removed
by removing the 4 screws and lifting the paddle / ice
chute out of the housing.
On models that only dispense water and ice cubes the
dispenser will come apart the same way as models
with a control board. The difference is there is no light
in the housing and the wiring to the actuator switches is
connected directly the plug in the door wiring harness.
volodia62
#3 Posted : Thursday, May 26, 2011 8:08:54 AM(UTC)
volodia62
Instructions great. Thanks, I just saved $159.00. It is back on line and working again. Volodia
Joe / APP Team
#4 Posted : Thursday, May 26, 2011 8:27:14 AM(UTC)
Joe / APP Team
Volodia,
Great !!!!
Thanks for the update, remember, we're here to help.
Good Luck,
:D :D :D
