my dishwasher is going through its normal cycles but for some reason not circulating the water it just fills with water and then drains. would that be my circulation motor?
Pull the plug of the motor and see if you are getting power if so replace the motor if not replace the control power to motor needs to be chked when water should be flowing. I would also order new o-rings if motor is to be replaced. hope this helps.
