AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Agitates, won't spin.. makes loud belt noise.. every other cycle works fine.
Sounds like belt is slipping, not allowing drum to turn..drum will turn manually..can someone help me ??
Originally Posted by: dolfan4764 Sounds like belt is slipping, not allowing drum to turn..drum will turn manually..can someone help me ?? My washer is direct drive (no belt) I founfasock in the pump easy repair. The noise was the moter
Washer Repair
