DISHWASHER touch pad stuck in sensor wash blinking all time things I have tried Reset by turning off (5-10min)turned back on /checked water supply ok first cleaned sensor /Replaced sensor touch pad tested as per instrucions disconeted from ctl board watched dishwasher and did what instrucions say run pump for 2 minutes all ok as far test but put back all togehter still same problem touch pad still stuck in wash sensor blinking no other button works I think is a bad control board need some help here Help please washer is only 1 1/2 years old just out of warranty been told board warrantied for 5 years only if their tech staff comes to check out but still have to pay for labor as per Jenn-air need help thank you :(
Hello, If you replaced the touch pad and it still does not respond you are correct the control board has failed. ApplianceRepairLesson.com
I did not replaced keypad / I tested as per instrucions disconeted from ctl board then tested by powering back on (now disconeted touch pad is Death)dishwasher runs pump per 2 minutes, as per instrucions enclosed in dishwasher this indicates touch pad is OK / powered down conect touchpad ribbon to ctl board / power back on / same nothing changes / this only lead me to belive problem still the main ctl board what you think?
replaced ctl board still same trouble need help here touch pad very very expensive maybe not worth to fix and dishwasher is only 1 1/2 years old very unreliable unless find out what is the problem please reply
If you have replaced the control board the only thing let that would cause this issue is the touch pad. Most of these units do have a five year warranty on the control and touch pad. If a technician can replace it under warranty for less than $150 I would repair it. These are solid units and have been around the block. Everything has issues and you will never buy another dishwasher or appliance for that matter that will last. ApplianceRepairLesson.com
