Even after the stove top has ignited, the ignitor continues clicking. I have had a repairman come to fix the problem with no success.
Bosch NHT72 gas stovetop
Any help is appreciated! Merry Christmas
Make sure the ceramic part of the igniters are not damaged. Clean the igniters, using a rubbing alcohol. Make sure all burner caps are in the right position and burners are properly grounded. Check for the proper polarity on the electrical connection. If there is nothing wrong then replace the spark module. - The part number for the igniter is AP3196470 - The part number for the spark module is AP3193568Here are the break down diagrams for the Bosch cooktop Model NHT725Happy New year! Gene.
