lois kincaid
#1 Posted : Tuesday, December 23, 2008 9:01:21 AM(UTC)
lois kincaid
My fridge is working fine but makes a rhymical moaning sound when the motor is running. What's going on? How can I make it stop?
kooler
#2 Posted : Tuesday, December 23, 2008 3:50:53 PM(UTC)
kooler
It would help some if you listed a model number but if your Hotpoint's 'moaning' sound is more along the lines of a 'distant train whistle' sound then you're fridge is a likely candidate for a new control board replacement... It's also possible that this may be a warranty part so contact APPros or a local Pro with model AND serial number handy... cheers, kooler
O'Shark
#3 Posted : Saturday, January 17, 2009 3:13:49 PM(UTC)
O'Shark
I have the same problem. I checked and remedied the most obvious things like dust accumulation but I suspected it was the control board. The fan inside the freezer speeds up and slows down and whistles like an old fellow taking a nap ;).
It's a Hotpoint Model HSS25GFPJ WW. It was purchased by the previous homeowner in 2005 so I assume that I am not a warranty case.
