Having a slow/low fill problem. This is what I have done so far to repair:
1) Replaced the water shut off valve. I had a big chunk of solder in it when I took out the old one
2) Removed the water inlet valve. Cleaned it and replaced the diaphram in the piston.
3) Blew out debris from the shut off valve. Another big piece of solder was in the line
4) Blew out the plastic line from the water inlet to the tub. Nothing in there
5) Checked water pressure...Seems fine from the shut off valve to the water inlet
6) Also cleaned out debris from the chopper to insure no obstruction there.
Water fills for around 40 seconds. Nowhere near enough. If I add another pot full or two of water, upper spray arm rotates fine. If not, no rotation
Any idea? THe water inlet valve is suspect to me.
THIS FORUM IS DEAD!!!!!!! |
The inlet valve was the problem...Thanks...Who would have thought that what began as the top arm of the dishwasher not spinning would have ended up to be a bad inlet valve at the bottom...
