dirty dishes
#1 Posted : Monday, February 28, 2011 2:36:26 PM(UTC)
dirty dishes
I have a 3 year old dishwasher. the dishes weren't getting clean in it. When i inspected it I found the lower arm was not attached. It was floating ande not spraying. How do Iget this atached? Is there an assembly picture you may have?
Joe / APP Team
#2 Posted : Tuesday, March 1, 2011 12:07:32 PM(UTC)
Joe / APP Team
Dirty Dishes,
This should be your lower wash arm,
Part number: AP3875429
It is a somewhat twist/lock fit.
Here are some instructions from the service manual.
Lower Spray Arm, Fine Filter, and Inlet Cover
Check the holes in spray arm for bits of china, seeds,
and other foreign matter. Also check the spray wash
arms for rotation. If soil is present, clean fine filter
screen.
The lower spray wash arm can be removed by
gently lifting and rotating it counter clock wise.
The nut hub can be removed by rotating it
counterclockwise.
Caution: Use care to avoid breaking the clip on the
hub when removing the main conduit from hub.
Note: When installing the fine filter, make sure the
drain port of the filter is engaged with the drain for
the fine filter.
