jergen
#1 Posted : Monday, February 28, 2011 12:34:20 PM(UTC)
jergen
I ordered a lower door seal #4172127. It appears that the channel in the seal is larger that the bottom of the door. Do I glue the seal on, or am I doing something wrong.
#2 Posted : Monday, February 28, 2011 2:09:14 PM(UTC)
This seal should come with the installation sheet. Have you received it?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDV24SEBL1 | AppliancePartsPros.com
jergen
#3 Posted : Monday, February 28, 2011 2:23:32 PM(UTC)
jergen
Yes I did receive the instruction sheet. I doesn't tell you how to install the lower door seal. I does explain how to put the tub seals in. Any suggestions on the lower door seal? My old on was laying on the lottom of the door opening, so I couldn't use it as a reference for the new seal.
#4 Posted : Tuesday, March 1, 2011 3:09:27 PM(UTC)
I'm not sure which instruction sheet you received. The correct instruction sheet is attached to the reply.
File Attachment(s):
4172128 Lower door seal installation.pdf (92kb) downloaded 22 time(s).
kitchenaid lower door seal installation (Dishwasher Repair)
by frbianco 2/27/2012 11:21:03 AM(UTC)
Lower Door Seal Installation (Dishwasher Repair)
by DougB 12/11/2007 2:09:42 PM(UTC)
