2 Pages<12
Why42
#11 Posted : Thursday, March 25, 2010 10:42:27 AM(UTC)
Why42
I also have Kenmore same model ,Did all the same test ,Transformer,Cap,Diode all results normal as per test tech-sheet .
Will a Magnetron make a loud noise ?
Thank You.
#12 Posted : Thursday, March 25, 2010 5:58:12 PM(UTC)
Originally Posted by: Why42 Go to Quoted Post
...Will a Magnetron make a loud noise ?...
Yes it's possible, especial if there is continuity between each of the two terminals and the body of the magnetron.
Why42
#13 Posted : Friday, March 26, 2010 12:01:33 PM(UTC)
Why42
Magnetron - Continuity between each of the two terminals good .7 ohm --Terminal to Body infinite.
I see it arcing inside the magnetron terminal box form a small hole in corner of box .
CK HV Cap with a 9V battery and meter -Terminal to Terminal 9V ------Terminal to case 0v same results as info in tech-sheet .
Diode with 9v test CK good .
Magnetron ???
Any other way to test it ?
Thank You.
#14 Posted : Friday, March 26, 2010 12:32:54 PM(UTC)
...I see it arcing inside the magnetron terminal box form a small hole in corner of box...
The magnetron is the culprit. If you need the correct part number, post the complete model number of the microwave.
Why42
#15 Posted : Friday, March 26, 2010 1:55:11 PM(UTC)
Why42
Kenmore 721 6325930
Tag on Magnetron LG 2M246 05GF ::
Thank You.
#16 Posted : Friday, March 26, 2010 2:31:43 PM(UTC)
You are welcome. The magnetron Part number: AP4439646
Why42
#17 Posted : Friday, March 26, 2010 2:47:36 PM(UTC)
Why42
Thank You !!!! Your A1 !!!
Guest (7)
2 Pages<12
