MILLERHOME
#1 Posted : Sunday, December 21, 2008 6:08:46 PM(UTC)
MILLERHOME
You have been a member since:: 12/21/2008(UTC)
I Have A Simple Problem. The Rubber Insert That Sits In The Opening From Top Of Sink Is Worn Out. The Sink Will Not Hold Water And Tonite The Rubber Part Slipped Into The Disposal While In Use And Is Useless Now. I Would Like To Get A Replacement. The Model Number Is Facing The Back Of Cabinet When Installed So Can't See It.
#2 Posted : Monday, December 22, 2008 1:58:23 PM(UTC)
The model number is very important. You can try to read it, using a mirror.
GE garbage disposer not working (Garbage Disposer Repair)
by jdgolf 12/25/2009 7:48:18 AM(UTC)
