cat416
#1 Posted : Tuesday, October 16, 2007 5:25:13 AM(UTC)
cat416
new light switch in fridge, lights do not work in fridge ,freezer, ice and water at door. bulbs all good. prongs good at bases also cannot get the circulatin fan to work when i turn up the frigde t-stat the fan runs when you plug in unit then when you turn up the t-stat it stuts off. any ideas
Pegi
#2 Posted : Tuesday, October 16, 2007 10:35:50 AM(UTC)
Pegi
Strange, bad light switches can cause this but you replaced it...might check the wires where they go thru the door hinge area to see if they are broken....would suspect the thermostat but I do not know of the lights running thru the thermostats...they would be on even if the thermostat was turned off..almost sounds like a wiring harness problem somewhere..
