Dryer started fine last night and left it running at bedtime on a 40 minute dry cycle with a medium to small load. This morning found the door popped open, light on, clothes half dry- when I re-shut the door, the dryer would not start. No breaker was tripped, light works so there is power, tried reversing the door to see if it was the door connection...still no luck...any thoughts?
Not a good model number so cannot see if this one has the fuse that could be bad or not.
Check your door switch for continuity.
