bubba1273
#1 Posted : Friday, February 25, 2011 12:08:58 PM(UTC)
bubba1273
I have a whirlpool duet dryer and it shows an E1 code, I have changed the thermistor and it is still doing it. I have cleaned it out. I have had to change the front timer circuit board, and the side circuit board, so what would the problem be now?
murderurfriends
#2 Posted : Friday, February 25, 2011 3:21:31 PM(UTC)
murderurfriends
Wiring harness
#3 Posted : Saturday, February 26, 2011 3:46:50 AM(UTC)
I am assuming that you have the tech sheet.
I would also check your replacement thermistor with a meter.
Not unheard of to get a bad replacement part.
Guest (4)
