Oven preheats to 350 when bake is pressed If you raise the temp the setting comes down in 5 degree increments :confused:
Originally Posted by: hamgroup ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Oven preheats to 350 when bake is pressed If you raise the temp the setting comes down in 5 degree increments :confused: HAM, You most likely have a problem in the touchpad ribbon, to the control board, Try this first, Remove the control panel, disconnect the touchpad ribbon from the control board. Clean the end of the ribbon with alcohol, re insert the ribbon, and check the program pads for proper operation. If the problem persists, replace the control panel/key assembly. Good Luck, :) :) :)
