ezrob69
#1 Posted : Thursday, February 24, 2011 6:11:36 PM(UTC)
ezrob69
the dryer was working the cycle ended, put in another load and it wouldn't start. I checked the thermal fuse, door switch, and the start switch all showed continuity.
murderurfriends
#2 Posted : Friday, February 25, 2011 3:28:59 PM(UTC)
murderurfriends
Make sure you got L1-120v L2-120v and between both 240v if you have that also check the high limits and t-stats. If that works it could be a broken belt switch if your dryer has one.
ezrob69
#3 Posted : Saturday, March 5, 2011 7:04:31 PM(UTC)
ezrob69
I checked everything and it was the timer, took the timer a part and the keeper on the pink plaxtic disk on the control knob was broke. So I put some gorilla glue on it and put the timer back together set the timer to a dry cycle push start and now it works.
whirlpool estate dryer wont start (Dryer Repair)
by wayne5400 6/27/2011 7:54:20 AM(UTC)
Estate Dryer wont start (Dryer Repair)
by bmull 3/21/2010 10:11:34 AM(UTC)
