eugene413
#1 Posted : 14 years ago
eugene413
Lg Dryer Starts/ignites,but Then Loses Flame Altogether.
Checked Thermistats.all Checked Good For Continuity.don't Know What Else It Could Be.need Help.
eugene413
#2 Posted : 14 years ago
eugene413
this dryer has a limit and t-stat.t-stat limits the dryer temp.this is what malfunctioned on mine(dlg1320w). noone stocks this part locally. i was just luck enough to know how to jumper safeties to bypass and test. Part is on back order 10-14 days wait.
murderurfriends
#3 Posted : 14 years ago
murderurfriends
You don't wanna by pass any safeties especially in your gas dryer. Check your out side vent if it is clogged it will tripnthe limit. Also do not test machine with front panel off unless youmuse something to block the opening of the inside of the drum or it will not pull flame properly. Make sure your lp tank is not froze no clog in the office. Good luck. I did have one that was a bad gas valve but that would be last case scenario you should have the gas pressure ck!d
