bkirkman
#1 Posted : Friday, December 19, 2008 8:26:29 AM(UTC)
bkirkman
Dryer worked fine lasnight,,tried to turn on this morning and nothing?? made sure there was power and no blown breakers,,can hear the timer counting down when the dryer is plugged in,,when start putton is pushed it acts if there is just no power and does nothing,,also checked door switch and it seems to be working fine too
libertyappl
#2 Posted : Friday, December 19, 2008 9:01:02 AM(UTC)
libertyappl
Remove the rear panel of the dryer (Unit unplugged of course) that look for this part Part Details - WHIRLPOOL Thermal fuse (disposable, one time fuse), part number: 3392519. If you have an ohm meter test for continuity, if none replace. That should get your drying again.
Nat
whirlpool electric dryer not starting (Dryer Repair)
by fcarrelli 1/2/2011 12:55:10 PM(UTC)
Kenmore electric dryer not starting (Dryer Repair)
by seahawk4life 10/27/2010 8:01:49 PM(UTC)
