If the thermostat is set at 3.5 the comp. shuts off and will not come back on. Turn it up to 4 and it runs again but makes ice in the liquids on refrig. side. Looking from front this is thermo. on right
Check your air flow first. Place a thermometer on both sides and post your temperatures.
Nat
