kmarantz
#1 Posted : Thursday, December 18, 2008 4:16:51 PM(UTC)
kmarantz
I need to replace the dryer door switch assembly. I can't figure out how to open the dryer. It seems like it would be pretty easy but I can't seem to find the magic touch.
Thanks!
libertyappl
#2 Posted : Thursday, December 18, 2008 4:31:21 PM(UTC)
libertyappl
Here's your parts breakdown Model LGR5636JQ1
You will need to remove the lint screen & the screws by the screen. Then use a putty knife between the top & front and raise the top. Remove the two screws near the bottom on the front, pull up slightly on the front and remove the front.
Hope that helps
Nat
kmarantz
#3 Posted : Thursday, December 18, 2008 4:48:43 PM(UTC)
kmarantz
how do you detach the switch assembly?
libertyappl
#4 Posted : Thursday, December 18, 2008 6:32:48 PM(UTC)
libertyappl
If you haven't already check your email.
Nat
how to open dryer (Dryer Repair)
by michael.whitlockjr@yahoo. 1/10/2012 3:13:55 PM(UTC)
How to open dryer to repair belt or drum? (Dryer Repair)
by watstar 5/14/2010 5:00:22 PM(UTC)
How to open dryer to replace coils on gas valve (Dryer Repair)
by sing611 7/8/2009 9:22:35 AM(UTC)
