Hello, I need to replace the upper spray arm hose. Is that hard to do? Is there anything that I need to buy beside the hose? Does it come with instructions? Thank you! :)
What is the complete model number of the dishwasher?
Originally Posted by: blueeyez1958@comcast.net Hello, I need to replace the upper spray arm hose. Is that hard to do? Is there anything that I need to buy beside the hose? Does it come with instructions? Thank you! :) No it's not hard to do, but the dishwasher has to be completely removed from the cabinet because this hose goes outside of the tub. You probably can learn if anything else is needed only after you will take it apart. I do not think there are any instructions included because this part is not too difficult to replace. - The upper spray arm hose Part number: AP4111158
